Revell 1/24 HLF20 Varus 4x4
kpisnuts
Post by kpisnuts »
Never tried a truck before but saw this and had some birthday money soon,
​​​​​​​Image
kpisnuts
Re: Revell 1/24 HLF20 Varus 4x4
Post by kpisnuts »
Not sure what's happening here. Trying to paint the rad and fan blade washed the sprue as normal in soapy water but the paint won't stick I've primed it and taken it off 3 times (other parts on the same sprue were fine first time) the rad and the fan blade just won't seem to take the paint (it looks like a grease problem) I've scrubbed it with meths even but still get the same problem.
Help.
Joee159
Post by Joee159 »
I'm probably not the best person to ask but maybe you could try sanding down with some very fine git to give the paint something the stick to, or sometimes I find if I thin my paint to much it doesn't stick to well, hope it helps.
kpisnuts
Post by kpisnuts »
Thanks for the suggestion but the detail on the rad grill is so fine I would be worried about removing it.
Joee159
Post by Joee159 »
It's definitely a tricky one, other than that I'm really not sure
kpisnuts
Post by kpisnuts »
Hi all well ciff seems to have done the job so I've done some weathering on the engine and chassis.
kpisnuts
Post by kpisnuts »
Hi all here is the next instalment.
kpisnuts
Post by kpisnuts »
Some more work on the chassis.
It's a nicely detailed kit.
kpisnuts
Post by kpisnuts »
Hi all done a bit more to this super detailed chassis (Not done a truck before I'm amazed how much detail there is just in the chassis) I think I'm only about half way through it.
I've started on the cab also. I used foil on the roof
I think it looks too clean so I weathered it a bit and added some other details.
kpisnuts
Post by kpisnuts »
Hi all made a concerted effort on the chassis today, still a bit more to add (this really is a great kit I'm loving this as much as the London bus)
kpisnuts
Post by kpisnuts »
Done a bit more to this amazing kit, the fit of parts is perfect, they really have done a great job of this kit the parts are such a good fit I've used no glue on any of this part.
kpisnuts
Post by kpisnuts »
Hi all next update.
kpisnuts
Post by kpisnuts »
Hi all I love this kit, the fit is exceptionally good and the detail is great, again no glue
I tried a failed experiment the instructions say aluminium for this part so I tried aluminium foil
Yes I could try again but there are far more complex bits that have an aluminium background and this looks awful so I think I will use paint (although the ally doors will be simple enough with foil)
kpisnuts
Post by kpisnuts »
Hi all made a start on the many, many accessories in this vehicle.
kpisnuts
Post by kpisnuts »
Hi all I'm wondering if on the real thing these compartments are hinged some how
After adding this detail the other bit fits over the top like this
There are handles at the bottom of the outer shelving I'm wondering if I can some how make the parts hinged to show all the detail, there is loads of shelving like this and it would be a shame to hide all the detail.
Yes I could just not glue them so they are removable but I would like to try and make them as they are on the real thing.
kpisnuts
Post by kpisnuts »
Hi all here is the next update, I would really love to add lighting to this but can’t find leds small enough.
It’s a good job I’ve not glued the cab on yet as I’ve missed some painting
kpisnuts
Post by kpisnuts »
Hi all here are more of the many, many accessories for this vehicle
DrSprue
Post by DrSprue »
Wow, Im not sure how I missed this. Man that coming out nice. Love the detail work in it too. :thumb2:
-Doc
kpisnuts
Post by kpisnuts »
Hi all here's another update, I thought I could improve this bit so I cut the moulded on straps off and made some of my own
Then I thought to myself I can improve on that too.
I do think my bench is getting quite full (and this is not all I'm working on)
Here's an assortment of the accessories so far made for this.
DrSprue
Post by DrSprue »
Looks cool! Love the detailing. :thumb2:
-Doc
exmoor
Post by exmoor »
Doing a great job there love the detail
paul shapland
kpisnuts
Post by kpisnuts »
Hi all well thanks to Eddie Mc Vea and his pics here is the next update, I've added the missing cap holders to the hose clamps
There is actually loads of missing detail from this bit and I'm not sure I have the skill to add it but I may try (see if I can work up the courage)
kpisnuts
Post by kpisnuts »
Hi a little more progress
kpisnuts
Post by kpisnuts »
I've hinged this bit with some sticky backed aluminium foil
kpisnuts
Post by kpisnuts »
Hi all well I'm not sure I will actually do this but I've added some blue leds for the emergency lights, maybe I will and maybe I won't we will just have to see how complex it gets.
kpisnuts
Post by kpisnuts »
Hi all well it has working emergency lights.
I've glued aluminium foil behind the headlight holes to help them look more like headlights.
kpisnuts
Post by kpisnuts »
Hi all well here is the next bit, you really get a lot of kit for your money with this beast but I think I'm nearing the end now.
kpisnuts
Post by kpisnuts »
Hi all near the end now, loads of decals to add but the basic kit is nearly done. This really is a lot of kit for the money and I have had so many ideas for different versions of this so this won't be my last build of this or the London bus (another incredible kit)
kpisnuts
Post by kpisnuts »
Hi all nearing the end now (loads of decals to add and a small amount of painting to do) I've really enjoyed this kit not found a bad fitting part on it, although it is quite complex and some parts need a few trial fits till you figure out how they actually go together.
DrSprue
Post by DrSprue »
:thumb2: :thumb2: :thumb2: looks really cool...
-Doc
