Zvezda 1/72 Yak-130 "Mitten"
TommyKillander
Post by TommyKillander »
Hey Guys,
I'm starting a new build of the quite new 1/72 scale Yak-130 kit from Zvezda.
This will be a buddy build together with ChancerNW, a gentleman that contacted me on YouTube. I will make vlogs on my YouTube channel, but I will also put up a regular build-thread as well ;)
I did a YouTube inbox review of the kit a while ago, so I will not go into the details of the kit.
[youtube]n2FptPydmOA[/youtube]
But here's the box contents anyway:
The subject itself is a modern trainer and light attack aircraft produced by russian manufacturer Yakovlev. It's NATO codename is "Mitten" :crazy: :wtf: :D
So.... The build starts off with assembling the engines.
Kit parts look wornderful.
I will paint the airscoops before assembly. I'll use Gloss Black Primer andf ALclad Duraluminium for the metal parts and Ultimate White primer and Tamiya X-2 for the white air intakes.
Assembly of the parts for the main landing gear bays
A sneak-peek of the PE fret to make sure that there are no PE parts that should be included. But all parts seems to go into the cockpit ;)
Assembly of the engines. Everything fits together perfectly, but the kit is quite engineered :tongue:
Ok.... back to the landing gear bay.. Got some ejection pin marks to fix.
Dryfitting.... just to check that everything aligns up properly ;)
Bottom plate with landing gear bay seprator (sidewall)
...and a small navlight :)
Here's the first episode of the buddy build video:
[youtube]ZRHSm3EHoLg[/youtube]
Stay tuned!
Tommy
TommyKillander
Re: Zvezda 1/72 Yak-130 "Mitten"
Hey Guys!
The build goes on with completion of the main undercarriage and the rear half of the fuselage.
Great details but there are some need for cleaning up mouldlines
Preparing the leading edges of the airscoops for paint... starting with Ultimate White primer
...and X-2
Rest of painted details primed with Grey primer
Tubing should be painted with Trainer Yellow - but this is the closest I have at hand Gunze H34
Landing gear compartment and oleo struts painted with Gunze H308
Glued together and some touchup with metal colour
Masked for metal paint on the air intake leading edges
Some weathering - maybe too much :? :shifty:
Masking for flat coat
Gluing in the bottom part in rear fuselage
Some gaps that needs attention...
This will need a lot of work to fix... I'm thinking of adding a thin sheet of plasticard to cover up the seams... :think:
Next up is the cockpit - that's always fun :thumb2:
Tommy
Fridgy
Post by Fridgy »
Yet another interesting build tommy!
Coming along nicely
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
TommyKillander
Fridgy wrote: Sun Feb 04, 2018 10:48 pm Yet another interesting build tommy!
Coming along nicely
Thanks Fridgy! :)
Tommy
DrSprue
Post by DrSprue »
Yea, watched your video as well Tommy and it was really cool. Awesome... your doing it on here as well. Count me in for some popcorn! :pop: Very good sprue layout too up top. Looks like a great kit!
-Doc
TommyKillander
DrSprue wrote: Mon Feb 05, 2018 6:37 pm Yea, watched your video as well Tommy and it was really cool. Awesome... your doing it on here as well. Count me in for some popcorn! :pop: Very good sprue layout too up top. Looks like a great kit!
Thanks Tony! :)
There are plenty of popcorn to go around :pop: :pop: :pop:
Yes, it's a really good kit and the aircraft is really cool too.
Take a look at this 1/4 scale Yak-130 RC jet - awesome work! It's so good that it's useful too look at for reference when building.
[youtube]6QLU5GH3J44[/youtube]
Tommy
TommyKillander
Hello again!
It's time for building and detailing the cockpit - my favorite parts :banana:
After the first shock and initial "photo etch vertigo" have stopped it's time to plan which parts that I will replace with PE and what parts that look good enough (or are far to complicated compared to what the offer). After that we're ready to cut some parts loose from the sprue.
Parts cleaned up
Removing details to make room for PE :crazy:
First set of parts ready for primer
Trying out the trick with putting the primer bottle in a warm water-bath
...and it worked like a charm - great suggestion :th:
The office painted with XF-1 and XF-23 - it's not the perfect match but is works great with the painted PE panels.
HUD in PE :wtf:
There's tons on small details where most of them goes into the cockpit, but I'm not gonna use all of the.
I have painted the MFDs black, because the aircraft will be gear down. Coated the screens with X-22
Some drybrushing of details and worn surfaces
Small details.....
HUD projector lens
Flatcoated all parts (except the MFDs that should be semigloss) and started the assembly :dance:
HUD glass :wtf:
...and there you have it!
Tommy
I've been thinking of buying this kit. It looks like a sweet little plane to build, too. And, as much as I hate photo etch, it really makes the cockpit stand out!
TommyKillander
DBMiller wrote: Mon Feb 05, 2018 8:53 pm I've been thinking of buying this kit. It looks like a sweet little plane to build, too. And, as much as I hate photo etch, it really makes the cockpit stand out!
It's a great kit, I can really recommend it! The only downside I have found sofar is that the Assembly Instruction is a bit sparse and there are some minor errors, but the kit parts are fantastic and it's really fun to build!
Tommy
TommyKillander
Allright!
I'll continue with the remaining parts of the undercarriage
Really tiny parts for the nose landing gear - will that tiny leg really hold the weight of the aircraft :think:
Primed
Painted with Gunze H319, Tamiya XF-85 and Gunze H308
Not far behind resin level of detailing here... Airbrushed the main wheels and the hub of the nose wheel
Brushpainted the XF-85 on the nose wheel
Sidewalls painted with Tamiya X-23 added a smallPE sign too
Some noseweight
Tommy
DrSprue
Post by DrSprue »
Looking cool Tommy! :thumb2:
-Doc
TommyKillander
DrSprue wrote: Tue Feb 06, 2018 9:47 pm Looking cool Tommy! :thumb2:
Thanks Tony!
So, the build continues... :D
Well, first bit of setback; the assembly instructions is a little vague about the location of the IP-cover and there is no location-pins or any other reference to tell where it should sit - so I tried to guess a bit but it didn't work :bash:
I had to pry it off and put it in a better location... :violin:
I added the windshield to protect the HUD, since I had already destroyed it once and had to fix it :crazy:
Sanded down the injection ports, glue filler of the seams and polished the surfaces
Masked the insides of the airscoops to protect the bare metal stripe on the inside
...now I need to figure out how to mask and paint the outside... :shifty: :scratch::
Mated the fuselage sections and fitted the top of the air intakes/funnels :dance:
Here's the second episode of my buddy build update:
[youtube]ZEKhAgZwVVI[/youtube]
DrSprue
Post by DrSprue »
Watched the vid Tommy! left a msg on utube as well. :thumb2:
-Doc
TommyKillander
DrSprue wrote: Wed Feb 07, 2018 8:41 pm Watched the vid Tommy! left a msg on utube as well. :thumb2:
Awesome! Thanks! :thumb1:
Tommy
Lookin' good!
TommyKillander
aur0ra145 wrote: Fri Feb 09, 2018 8:08 pm Lookin' good!
Thanks bud ! :D
Tommy
TommyKillander
Hello!
My family have been down and out (winter vomiting bug) for almost a week. But now everyone, me included, are up on our feet again. :bash:
So let's continue with the build now!
Using some kitchen foil as a reflector for the nav light
Dryfitting the top wing section - the fit is not 100% perfect, but let's worry about that later
We need to finish some seams on the fuselage first. Remeber those difficult seams on the exhaust heat shield ?
The thing with CA-glue is that it is much harder than styrene, so a soft sanding stick will not sand down the surface evenly. I got sanding sticks with a hard back for that purpose, but in this case I need something round to wrap the sanding paper around. I found an old brush handle that I sacrificed :shifty:
...and it worked fine.
I will put that aside for 24 hours so the primer cures before I put on the Stainless Steel metal
Painted the sidewalls - I think this is the third section :D
Meanwhile, let's prepare the rest of the parts needed for the wings
SNPU-130 Gunpod
Tommy
TommyKillander
Hey guys!
Short update today; I just painted the metal colour on the exhaust heat shield.
I decided to use a lighter metal tone, since I want to do some heat staining and weathering - so Duraluminium is a better choice than Stainless Steel I think.... :think:
Tommy
TommyKillander
Ohai fellas!
I have done som thinking about the paint-scheme of the Yak.... :think: :scratch:: :shifty:
I found this exciting paint scheme - looks awesome, don't you think ?
Just kidding.... a B/W paint-callout is just so much Zvezda.... :bash: :crazy:
They should really invest in a colour leaflet for the paint callout....
Instead let's look at some reference pictures:
The loadout will be something based on this picture:
Wingtips will have ECM pods followed by R-73E Wympel AAM.
The next two pylons will have a S-8 and S-13 rocket launcher pod each and finally a SNPU-130 gunpod in the centerline position.
:banana:
Tommy
Fridgy
Post by Fridgy »
Love the colour scheme tommy
You akways pick the funkiest looking projects
Mick
TommyKillander
Fridgy wrote: Thu Feb 15, 2018 9:07 pm Love the colour scheme tommy
Thanks Mick ! :)
Haha... Yeah, maybe I do :D ;)
Tommy
TommyKillander
Hey Guys!
It's not much left to assemble now, before I can start painting.
Next up are the wingsections:
I will paint the pylons in the same colour as the underside, so I will glue in the hardpoints aswell
ECM pods for the wing-tips
Weapons; I decided to make a last minute change - the S-13 rocket launchers where replaced with two KAB-500Kr Optical AGMs
It's quite a loadout for a pocket-sized aircraft like that ;)
Tommy
NormanD
Post by NormanD »
It's the sort of aircraft you just look at and say "Cute" looks to be a fun build Tommy
TommyKillander
NormanD wrote: Sat Feb 17, 2018 5:04 pm It's the sort of aircraft you just look at and say "Cute" looks to be a fun build Tommy
Yeah I agree, it looks really cute :)
Belarusian Airforce will team up their Yak-130s with Su-25s; speaking of the beauty and the beast :tongue:
http://airheadsfly.com/2015/09/28/belar ... ith-su-25/
Tommy
DrSprue
Post by DrSprue »
It just looks so sleek!
-Doc
TommyKillander
Hey Guys,
It's been a slow day at the bench... didn't get much done at all.. :crazy:
Well well, but I cleaned up the ordnance preparing it for primer. Drilled out some holes for the pins on the hardpoints. I will use them to put all the small stuff on cocktailsticks ;)
I also sanded and down some seams and polished the surfaces with a buffing stick. The only critical seam that is left to take care of is the joint between the cockpit tub and the main wing - I wasn't able to solve it despite my attempts to dryfit and find the cause of the gap.
But this is the only serious fit issue I have seen with this kit sofar..... I have no problems to accept that.
I filled the gaps with sprue-glue
Now I need that to cure for a couple of days, so I will continue with the ordnance...
I started by gluing the ECM pods to the wingtips
Tommy
TommyKillander
Hello (or Hellö as we say in Sweden)
Short update!
I have started to put primer on the weapons!
And after a couple of days the sprue-glue had cures so I could sand down the excess material and get rid of the seams
Next up is masking :banana:
And I will do a quick vlog update soon too!
Tommy
TommyKillander
Hey!
Here's a vlog update on the build progress:
[youtube]_Shev9YyLLg[/youtube]
Tommy
TommyKillander
Ohai guys!
Started the masking and painting this weekend :banana:
Canopy masked.
Undercarriage and engine inlet and exhausts masked
Added the small pitot tubes. Normally I add the small parts last thing, but in this case I wanted the joints to conform with the fuselage side.
I'm aware that I spend a lot of time on masking the model before painting, but I believe that it's the only way to do it if the details should remain crisp...
But now it's time for primer!
... but I ran into some problems right out the gates :violin:
I bought this 120 ml bottle back in the days before Ultimate had the distribution for Stynylrez Primer in Europe - two years ago or something. Since I'm mainly building 1/72 aircrafts the bottle have been *very* long lasting :tongue:
But now it's time to retire it ;)
With a new bottle everything worked as expected :thumb2:
So.... In order to plan the paintjob I need to convert the Zvezda/Humbrol paint callouts to Gunze/Tamiya. I got a paint conversion chart in the latest issue of Airfix Model World.
I selected these paints for the cammo
Here's the subject:
Bare metal for the S-8 rocket launcher pods
XF-2 White for the Wympel missiles
I did some experimentation with XF-2 White and X-19 Smoke for the optics of the KAB-500Kr AGM.
I'm not superhappy with the result, so I might have to do something more.... :think:
Stay tuned...
Tommy
That color scheme will be quite striking!
I was looking around for different marking for this plane when this showed up on my Facebook feed. Twin sons of different mothers.
ImageM-346 by Donald Miller, on Flickr
From Wiki:
The Alenia Aermacchi M-346 Master is a military twin-engine transonic trainer aircraft. Originally co-developed with Yakovlev as the Yak/AEM-130, the partnership was dissolved in 2000 and Alenia Aermacchi proceeded to separately develop the M-346 Master, while Yakolev continued work on the Yakovlev Yak-130.
TommyKillander
DBMiller wrote: Sun Feb 25, 2018 1:53 pm That color scheme will be quite striking!
From Wiki:
Cool! Are you planning to build the M-346 Master ?
It's basically the same aircraft, but the are some differences too - like the landing gear for example; I guess that russians and italians have different standards for their runways ;) :D
Tommy
TommyKillander
Quick update!
I wasn't 100% happy with the Gunze H21 for the belly of the aircraft, so I mixed my own brew from Tamiya paints. Don't ask me about the ratios; I have no clue how many drops I used of the paints :crazy:
Painted the gun pod with Vallejo Metallic and XF-82 Ocean Gray
Painted the underside part of the aircraft with my "Off White"-mix.
I will leave it until tomorrow when I will continue with masking :)
Tommy
TommyKillander wrote: Sun Feb 25, 2018 4:20 pm
Tommy
[/quote]
I'd love to get one someday. I think the biggest difference, from what my parents experienced in Italy, is the installation of a horn to clear the way as they taxi out to the runway! ;)
TommyKillander
wrote: I'd love to get one someday. I think the biggest difference, from what my parents experienced in Italy, is the installation of a horn to clear the way as they taxi out to the runway! ;)
:D :lol:
Italian cars have two horns, if the first one gets worn out. That way they have one fully operational on the way to the repair-shop.
[youtube]AjGXn249Fc0[/youtube]
Tommy
TommyKillander wrote: Sun Feb 25, 2018 7:53 pm
:D :lol:
Tommy
:th: :th:
TommyKillander
Hey Guys!
It's masking time - yay! :crazy: :shifty:
I'm masking the underside to protect it from overspray - it's amazing how paint dust can find it's way (to where it shouldn't be)....
Topside ready for the first cammo colour
I usually start with the lightest colours first and the darkest one last.... This is Gunze H308 for the light grey areas
I'll let that cure until tomorrow, when I will continue with masking and the light green..
Tommy
Fridgy
Post by Fridgy »
Looking forward to the next few updates on this one tommy
Mick
:D :lol:
Tommy
One of my favorite childhood movies. Original Gumball Rally
The Lambo girls were my favorites :D
TommyKillander
Twokidsnosleep wrote: One of my favorite childhood movies. Original Gumball Rally
They where everybodys favorites - depending on taste you could admire the car, the girls or both ;)
Okey... the painting continues:
Masking the light grey areas. Panzer Putty is awesome!
Light Green sprayed on.
MEDIC !!!! :o :o
I dropped the model into the workbench and broke the nose-wheel leg :violin:
But I think I fix that. It's just a bit annoying :(
Tommy
How well does that putty work? I really need a new way to mask - I keep messing up everything else.
TommyKillander
DBMiller wrote: Thu Mar 01, 2018 3:49 pm How well does that putty work? I really need a new way to mask - I keep messing up everything else.
Panzer Putty is fantastic! :banana:
I can really recommend it :th:
Masked and painted the Dark Green
Unmasking :shifty:
There you go!
There are a couple of mistakes on the bottom side that I need to fix and the cammo is not exactly like the reference pictures - but I'm happy with it anyway.
Next up is to mask the nose, tail and top of the vert stab and put on some Dark Grey.
Tommy
TommyKillander
Hello,
The painting adventure continues... :tongue:
Masking to fix some mistakes on the underside
Cammo finished
There's only some detailpainting left, after that it's time for glosscoat and decals :th:
Tommy
TommyKillander
Hey Guys!
I forgot to paint the bare metal leading edges of the air intakes earlier; so I will have to do a bit of funky masking job now... :? It had been much easier to paint it earlier on and masking the edges ;)
....but I got there in the end :thumb2:
I had to use Vallejo Acrylic Metal, since I already had painted it with Tamiya acrylics. Alclads doesn't work well on top of acrylics... :)
Got some Aqua Gloss on!
I was a little worried that the glosscoat would darken the "off-white" and make it too yellow - but it looks just fine :thumb1:
I took a closer look at the decals; in general they look fine but I'm a bit worried about silvering of those large decals. I might have to trim them before I put them on.
I will leave the gloss to cure overnight and I start decalling tomorrow :dance:
Tommy
TommyKillander
Awwrajt!
It's time for the decals (and stecils :crazy: )
All setup - even got a cup of coffe on the side...
So far so good... :shifty:
I was a bit woried about the large decals on the wingsection. So I trimmed the decal by removing the large transferfilm section...
Drawback was that it was really difficult to align the lines.... :crazy:
....and we run into the first serious "I goofed up"! :ooops:
I left a couple of large drops of Micro Sol on the "No Step"-stencils and it ate through the Aqua Gloss and first layer och paint.
I will have to fix this.... :think:
Some of the stencils are barely larger than fly-poop!
I will continue tomorrow with the stencils... :D My eyes need to rest now :crazy:
Tommy
DrSprue
Post by DrSprue »
That Yak is looking pretty cool now Tommy! :thumb2:
-Doc
TommyKillander
DrSprue wrote: Sun Mar 04, 2018 9:03 pm That Yak is looking pretty cool now Tommy! :thumb2:
Thanks a lot, Tony! :D
I think it will look great loaded up with all the ordnance and some matte coat to take away the "toy-look" :)
More stencils.... :crazy:
Now there is only the stencils on the weapons left to do....
Stay tuned!
Tommy
TommyKillander
Hello!
More stencils..... :shifty:
But it's only the gunpod left now...
Speaking of the gunpod; I have painted it in the wrong colour :bash:
But it should ofcourse have the same colour as the belly of the aircraft :ooops:
So let's hit it with the last drops(!) of our homemixed paint
Stay tuned!
Tommy
TommyKillander
Hey Guys!
Painted some bits and bobs...
I also fixed the lenses of the KAB-500r; I was never happy with my first attemp, so I repainted the tip with X-2 White and dipped it into X-19 Smoke so I got a dark semitransparent look. After that masked the tip with a small masking tape roundel and sprayed the missile with XF-82 once again.
It looks much better now I think :thumb1:
I decided to fix the ruined paintjob on the leading edges of the wings... so yesterday I coated the decals with Aqua Gloss to protect the decals. After that I cut thin strips of masking tape and "detacked" them a bit. I used Panzer Putty for the masking as well.
Light green sprayed on...
More masking and Dark green sprayed on... just tiny tiny amounts of paint (2 drops thinner annd one drop paint) :crazy:
Next up is the Light grey...
And we are finished!
The paint will look more uniform after a layer of Aqua Gloss.
Tommy
Just caught up on this one Tommy - that's a great build of a really unusual aircraft :clap:
Superb save on the wing paintwork as well - I'm always wary of patching stuff up like that!
TommyKillander
Tomcat64 wrote: Fri Mar 09, 2018 11:57 am Just caught up on this one Tommy - that's a great build of a really unusual aircraft :clap:
Thanks Neil! :)
It's not so difficult - more like "do I really want to do all the extra work"... But in this case I thought it was worth it ;)
Tommy
