#14 1/72 Tamiya De Havilland Mosquito
Fridgy
Post by Fridgy »
Afternoon fellow capitains....
My entery to this Sig with be as follows
This kit was donated to me by a good friend when I was struggling $$ wise :bow:: :clap:
Im hoping I can do it some justice
Anyway here are the sprue shots etc
Chose the colour scheme purely on the fact that it is the only one with some nose art.... and a grim reaper at that! :banana:
Wish me luck boys.... Tally Ho!
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
Re: #14 1/72 Tamiya De Havilland Mosquito
All right, who let this Lagger Lout into the sig ;) :tongue:
Looking forward to see a night version if this Mossi...I think that is what you said you were doing
Awesome to see you set it up and great to have you along and I do wish you luck my friend :thumb2:
:cheers2: bud
Mylightweight
Post by Mylightweight »
I love a good mossie, never see one with nose art though.
On the bench;
Tamiya Dragon Wagon & Jagdpanther
RFM Bergepanzer Tiger 1
Eduard Spitfire mk IXc
Bomber SIG
In the stash;
Too much to list, let alone build
Fridgy
Post by Fridgy »
A little historyof the 109 Squadron flying the Mossie
Taken from historyofwar.org
The association of the Mosquito with the Pathfinders began in August 1942. In that month No. 109 Squadron, a special duties squadron that had been working on the new Oboe radar navigation system, was transferred to the Path Finder Force (No. 8 (PFF) Group from January 1943). At the same time the squadron received Mosquito B. Mk IVs.
The Oboe system used two radar ground stations to pinpoint the position of an aircraft, guiding it to its target. It would be used by a small number of Pathfinder aircraft, which would find the target for a raid and mark it with flares. The main bomber force would then aim at the flares. If the Pathfinder’s could find their way accurately to their target, Bomber Command would have a way to bomb any target in Germany.
No. 109 Squadron flew the first Oboe mission on 20/21 December 1942, attacking a power-station in Holland. The success of this mission led to the first combined raid on the night of 31 December 1942/ 1 January 1943. This time two Mosquitoes from No. 109 Squadron used Oboe to find Düsseldorf. Once over the target they dropped parachute flares, and a force of eight Pathfinder Lancasters bombed the flares. This sky marking system could be used to bomb specific towns or cities in Germany in just about any weather. It was not precision bombing – the parachute flares were moving targets – but “Bomber” Harris didn’t want precision bombing – the last thing he wanted was for 200 Lancasters to drop their bombs on the exact same place!
The Oboe system could be used for precision bombing, as demonstrated on the same night as the Düsseldorf raid, when another force of Mosquitoes from No. 109 Squadron used it to bomb the German night fighter base at Florennes, Belgium.
After nearly a year as the only Mosquito squadron in the Pathfinders, No. 109 Squadron was joined by No. 105 Squadron in June 1943 and No. 139 Squadron in July 1943.
The Mosquito squadrons now began to combine Pathfinder duties with bombing raids of their own. The three Mosquito squadrons became known as the Light Night Striking Force (although Air Commodore Donald C. T. Bennett, the command of No.8 Group, preferred the term Fast Night Striking Force). While the main bomber stream could hit one or two targets per night, small numbers of Mosquitoes could be found roaming across Germany, keeping the air raid sirens busy. By the end of the war No. 8 Group contained eleven Mosquito squadrons.
Two developments helped make the Mosquito into an effective bomber. The arrival of the B Mk IX in April 1943 and then the B Mk XVI in December 1943 allowed the Mosquito to bomb from ever increasing altitudes, making it increasingly difficult for German night fighters to intercept the raiders.
More importantly, in April 1943 the B Mk IV was modified to carry the 4,000lb “cookie”, by then the standard bomb used by the heavy bombers. The first operational use of the capacity did not come until 23 February 1944, when No. 592 Squadron dropped the big bomb on Düsseldorf. The number of 4,000lb bombs dropped by the Mosquitoes of No. 8 group increased steadily. In the first five months of 1945 Mosquitoes dropped 2,959 “Cookies” on German targets. Berlin alone was visited 170 times by the LNSF. The B Mk XVI was the main Mosquito type used to drop these bombs.
This is not to say that the Pathfinder Mosquitoes concentrated entirely on bombing raids. They continued to act as Pathfinders for the main bomber stream, often both leading a raid and taking part in it.
The Pathfinders was also used for other special duties. One of these was “spoofing”. This involved a small flight of aircraft dropping Window, originally developed to block German radar, to mimic the radar signal of the main bomber force. This was done by dropping Window at careful intervals along a set route. It was first tried by No. 139 Squadron, on 18/19 November 1943. The hope was that the German night fighters would be directed onto the false bomber stream, ignoring the main stream. It could also be used as a double bluff, with spoofing force flying ahead of the main bomber force, in the hope that the Germans would realise that the first apparent raid was false and then ignore the main force. The same spoofing technique was later used by Lancaster bombers of No. 617 Squadron on D-Day, to create a fleet of ghost ships crossing the channel from Kent to the Pas-de-Calais.
1944 saw the appearance of H2S, a downward looking radar system that could clearly pick out urban areas. As this was carried by the aircraft, it did not have the same range limits as Oboe, and was ideal for targeting cities that contained large areas of water, amongst them Berlin, which contains large lakes.
The Pathfinder Mosquitoes ended the war with a most impressive record. In 28,215 sorties they had only suffered 108 losses, a lose rate of only 0.03%, the lowest of any aircraft type in Bomber Command. The Mosquitoes of the Pathfinder Force played a crucial role in improving the accuracy of Bomber Command, which by the end of the war had become a precision weapon, even if it was not always used as such.
Mick
Can't beat a good mossie :th: :th:
Les0012
Post by Les0012 »
A wooden wonder in plastic, canna beat it.
Good luck fella
Les
That was a really good read about the Mossie and her role and low mortality rate :clap:
I know that some bozos in Canada, Halifax I think it was, clipped a flag pole and crashed a Mosquito showing off.
Killed everyone on board. Was supposed to be a demo aircraft for the war effort
Funny I can't find the reference now
Anyhow, carry on :thumb2:
Fridgy
Post by Fridgy »
Alrighty.... Planning on making a start tonight, my girl are heading out to a friends for a girls night..... leaves me to my own devices at home...... So plastic therapy or ps4 vr therapy?? Decisions decisions......
Stay tuned
Mick
InvalidUsername
New Zealand
Post by InvalidUsername »
Fridgy wrote: Fri May 04, 2018 9:40 am plastic therapy or ps4 vr therapy?? Decisions decisions......
Stay tuned
Both :thumb2:
alextheblue
Post by alextheblue »
Love the mossie, such as classic shape.
Looking forward to this one! :pop:
www.alextheblue.com
Lovely aircraft, only the Brits could have come up with the wooden wonder!
Fridgy
Post by Fridgy »
Made a start tonight..... looked at the size of the landing gear where the instructions would have me start..... 1/72.... what was i thinking??? :wall:
So skipped a head quite a few steps to the cockpit, nose section and fuselage...
Have cleaned all the parts up and have been coated in Ultimate grey primer.... worked perfectly with mycheap chinese ab with unknown needle size.... :wtf:
Tomorrow with shoot somecolour at the parts and get some detail painting underway :thumb1:
Mick
gaz45
Post by gaz45 »
Cool bird there mate
pourquoi61
Post by pourquoi61 »
Looking good .
Have a cheap airbrush which I use very often with good results. :th: :th: :th:
Door prize draw coming up this weekend :banana:
Fridgy
Post by Fridgy »
Yay! some bench time today
Tommorrow is a day off for my wifes birthday
Anyway, got the interior sprayed green tonight
hopefully I will get some bench time this weekend to start the detail painting of the interior
Mick
Fridgy
Post by Fridgy »
Started some detail painting
Mick
Looking good :thumb2:
What green are you using??
Fridgy
Post by Fridgy »
Twokidsnosleep wrote: Thu May 17, 2018 4:41 pm Looking good :thumb2:
Morning buddy
Vallejo model air green sky
70.974 is what was laid down
Mick
Fridgy wrote: Thu May 17, 2018 8:48 pm
Morning buddy
Looks really good :thumb1:
Fridgy
Post by Fridgy »
Twokidsnosleep wrote: Thu May 17, 2018 8:59 pm
Morning buddy
Thanks mate
Instructions called for a mix of 3 different colours
But i found pics of the pit which matched up fairly well with the green sky
Much easier
Mick
Skullfish
Post by Skullfish »
Cool bird! Love the mossie , heard good things of the Tamiya. Kits
Good luck with her , following along.
Jase
On the bench.
Morning buddy
It's a good looking choice
:th: :th: :cheers2:
Les0012
Post by Les0012 »
Looking good, I am not one for mixing paints together it's just a pain to me
Les
Fridgy
Post by Fridgy »
Les0012 wrote: Fri May 18, 2018 9:06 am Looking good, I am not one for mixing paints together it's just a pain to me
Les
digger303 wrote: Fri May 18, 2018 3:59 am
Morning buddy
:th: :th: :cheers2:
Skullfish wrote: Fri May 18, 2018 3:03 am Cool bird! Love the mossie , heard good things of the Tamiya. Kits
Jase
Cheers fella's :cheers2:
Mick
Fridgy
Post by Fridgy »
Not a huge amount done this weekend, had to travel to Deniliquinn to help the step son move house
Just doodling away with some detail painting on the interior, might not be historically accurate, but meh.... its my model and it adds some visual interest
Mick
Some nice things happening here mate :th:
Les0012
Post by Les0012 »
Liking very much
Les
pourquoi61
Nice eye candy mate. :th: :th:
pourquoi61
Thanks for the idea. :cheers2: :cheers2: :cheers2:
Bent wings.
demarcation
Denmark
Post by demarcation »
Great work!! :th:
//Anders
Fridgy
Post by Fridgy »
Not much done lately
Got biten by the black dog early in the week and have struggled ever since
Slowly getting myself back together and gaining traction in life again
Mick
Fridgy wrote: Fri May 25, 2018 1:58 am Not much done lately
Happens to us all mate. You are not alone. Hang in there.
Fridgy
Post by Fridgy »
Stokesy44 wrote: Fri May 25, 2018 8:07 am
Cheers buddy
Mick
alextheblue
Sorry to hear that Mick, hope you keep managing to find that traction mate.
www.alextheblue.com
pourquoi61
I was walking with the black dog for 18 months when I lost my wife mate, you will get through.
Good luck and use plastic therapy to help.
Fridgy
Post by Fridgy »
Mojo took a big hit with my unwelcome guest, got back to the bench for about 30mins last night. Cockpit detail painted, just need to add the decals for the ip and the seat belts
Hopefully now ive got myself back to the bench i will be able to push on with this build
Mick
Fridgy wrote: Mon Jun 04, 2018 9:42 am Mojo took a big hit with my unwelcome guest, got back to the bench for about 30mins last night. Cockpit detail painted, just need to add the decals for the ip and the seat belts
Little steps at a time mate, little steps.
We have tons of time to finish and no pressure to do so
Model when it is enjoyable, not when you feel you have to
All the best to you
I'm not sure to understand what you have ?...I'm French speaking.... so don't give up!
Fridgy
Post by Fridgy »
some photos
Receiver
Transmitter
Cockpit assembled
Mick
Awesome details Mick :thumb2:
Great to see you back at the bench mate - that cockpit is starting to come together really nicely and as Scott said the details are starting to pop out too. Nice work mate :clap:
Les0012
Post by Les0012 »
Cockpits looking good
Les
Fridgy
Post by Fridgy »
Twokidsnosleep wrote: Wed May 02, 2018 10:15 pm That was a really good read about the Mossie and her role and low mortality rate :clap:
found it for you......
http://www.vintagewings.ca/VintageNews/ ... eddie.aspx
Mick
Fridgy wrote: Sat Jun 09, 2018 1:17 pm
Ya, there it is. Tragically stupid
Hope your mojo is returning. Your build has been great so far :thumb2:
demarcation
Denmark
Nice work on the cockpit, looks great!! :th:
//Anders
looking forward to seeing more of this. :th:
Fridgy
Post by Fridgy »
digger303 wrote: Sun Jun 10, 2018 1:27 am looking forward to seeing more of this. :th:
Twokidsnosleep wrote: Sat Jun 09, 2018 3:43 pm
Mojo is back... but (why is there always a but??)
The kids and grandkid are visiting this long weekend, which means the youngest has been kicked out of her room and has taken up residence in my modelling room..... i need a bigger house..... :bash:
Mick
Fridgy
Post by Fridgy »
Wings assembled
Forgot to add on of the nav lights in the wing... will try the pva glue trick....
Assembled the fuselage
Landing hear together, primed glossy black and shot some aluminium at it. Currently in the box drying
Mick
alextheblue
That's coming on a treat Mick! :th: :cheers2:
www.alextheblue.com
