1/48 Tamiya AR-196A with Eduard Details
Wolfman63
Post by Wolfman63 »
Next up is the Tamiya 1/48 Arado AR-196A German seaplane. I will be doing the scheme as one of the aircraft that were used on the Bismarck battleship. The Arado Ar 196 was a shipboard reconnaissance low-wing monoplane aircraft built by the German firm of Arado starting in 1936. To add details I am using the Eduard detail set. The first thing I noticed was aside from a few of the kit parts like the seats and some bulkheads the cockpit is 80% photo etch! There are 3 sheets of photo etch and most are the cockpit. It is taking a lot of time to cut, bend, and place the many parts but it is looking great.
You can see all the build photos and follow along in my build log at https://davidsscalemodels.com/build-log ... o-ar-196a/
Wolfman63
Re: 1/48 Tamiya AR-196A with Eduard Details
Post by Wolfman63 »
More work done on the Tamiya 1/48 AR-196A float plane.
I have completed most of the cockpit and installed it in the fuselage. The fit was a little difficult. The top of the cockpit walls fit fine but I had to twist it a bit to align it. If you ever go this route don’t install the cockpit to one side then join the fuselage. Put the fuselage together then install cockpit from bottom. I made a couple of shims to keep the cockpit floor square to the top.
I then started on the engine. The part with the pushrod’s had one pushrod that was “short shot” in the mold. I trimmed the nub and scratch built a new one using some stock styrene rods. The photo etch details and wiring were added and painted. After reviewing some photos of the real engine I used 32 gauge wire to make the oil return line. I cleaned up the cowl parts (the seams and a little flash) then installed the engine. The photo etch set also comes with the front cowl mounts. It was tricky getting them mounted the correct height so they would meet the cowl edge correctly. Once I finish cleaning the outside of the cowl and the assembly mounted to the fuselage I will be starting on the wings.
You can see all the build photos from the start at https://davidsscalemodels.com/build-log ... o-ar-196a/
