Ism Friday's night live at the bench what have you been working on for *May 29th*
**Open now until 1 hour before the show on Friday, May 29th**
onemanclapping
Ireland
Re: Ism Friday's night live at the bench what have you been working on for *May 29th*
Post by onemanclapping »
Hi Dan and ISM Crew.
Finished the 1/24 Revell Audi A4 DTM 2011
*primed with Ultimate White Primer
* Painted with decanted TS14 and the roof was AK Extreme Aluminium
* Decals laid down with Ultimate Decal Solutions
* Cleared with Pro Range 2K
* Polished with Ultimate polishing system
I was reasonably happy with the kit until I went to fit the body to the chassis.
It is way too tight and I am afraid I could damage something if I keep putting pressure.
Thanks for looking
Please find a deconstructed Audi A4
Got the D'Antin Pramac Ducati done! :banana:
1/12 Tamiya kit
Done with decanted TS-49 bright red and TS-40 metallic black.
Tamiya acrylics and some Alclad metal paint, over Tamiya white/grey primer.
Built oob, no detail up parts of any kind (couldn't find any, that were reasonable).
Added some Scale Motorsport CF here and there.
[Would like to try the magnets on the fairings, but apparently so does everyone else...]
Pretty satisfied with it, learning each time I do one.
Thanks! Happy Friday Guys. :thumb1:
Wingnut Wings the 'Duelists' Felixstowe [early] and Hansa-Brandenburg
Here is the first part complete The Hansa-Brandenberg another great build from WnW that went together without a hitch.
Vallejo,Tamiya paints mostly used and railmatch weathered black used on the floats.
ImageP5177553 by andrew purchase, on Flickr
Evening young Dan. You'll be devastated to know that I've finished mucking about with Eggy things and finished off the Tiger I dio I've been working on since February last year - hasn't the world changed since then!
This is Tamiya's 1/35 Tamiya I ausf E (late) which came with the crew included, with tracks from AFV Club. The figures are from a variety of Tamiya sets and the fuel drums and other assorted bits and pieces are a mix of Tamiya & Miniart. Finally the base is by Diodump.
Painting has been done with Ultimate primers, Vallejo Model Air & Model Colour, Andrea, Scale 75 & Lifecolour and weathering was done with a combination of clay washes, pigments & oils from a variety of brands with ground scatter from Diodump.
Stay safe & well everyone.
Hello everyone Friday is here :banana:
For bfrd’ s informal bike build on the super cool Forum, I am working on Tamiya’s 1/12 scale Ducati Panigale S 1199
It will be done in a yellow/white fairing scheme
I have used paint, glue and swear words so far
Actually it is a lovely Tamiya kit and goes together very well.
Having a hoot with the guys on the forum building the same thing together
Happy Weekend stay safe :thumb2:
Evening all,
Small progress on the 1/48 Kinetic EA-6B Prowler and 1/72 Airfix Buccaneer S 1C.
Prowler primed in a mix of Ultimate white and grey primers (really loving the colour) and topcoated with MRP-097 U.S. Dark Ghost Grey and Tamiya LP-5 Semi Gloss Black.
Bucc primed in that sexy Ultimate primer mix awaiting topcoat.
Have a great weekend everybody :tongue:
Al
ElCapitan
Post by ElCapitan »
This week I finished this Tamiya 1/35 SU-76 which I've been working on during my breaks from real work. The main colour is Tamiya XF58 Olive Green, and weathering has been done using mostly Ultimate dark dirt wash. I was tempted to get friul tracks but in the end decided to persevere with the fiddly individual links in the kit - had a couple of issues fitting them on but quite pleased with the end result.
ElCapitan
Good evening happy modellers!
Here is an almost completed 1/144 Fokker 70 in the livery of Alliance Airlines. The kit is a modified Revell Fokker 100 with Welsh Models engines. The main paints are Tamiya TS-26 Pure White, TS-83 Metallic Silver, TS-15 Blue, TS-47 Chrome Yellow - all decanted - and LP 54 Dark Iron and my own brew of grey. The decals are from the kit, Ric Warcup and Welsh Models.
Border Models 1/35 Leopard A6 finished.
Good kit just not great instructions, vague in places.
* Built completely out the box
* Primed in Ultimate Black primer
* Camo Freehand painted in Tamiya LP58/59/60 with the Ultimate apex airbrush
* Pin washed with oils
* Dot filtered with oils
* Mud and dust effects from Ultimate Washes Light Dirt & Earth
* Tamiya Lp paints used throughout and Ultimate Apex airbrush used throughout
CaptainBigelow
Post by CaptainBigelow »
Hello, I finished the Airfix 1/72 B-17 Mk.III in RAF markings. It was a great kit which went together really well. The surface detail was quite plain so I riveted the entire aircraft. I added resin engines, turbo chargers and wheels. It was painted with Hataka Lacquer paints and weathered with neat 502 oils.
I finished the Zvezda 1/144 scale Tu-160 tonight for the 80's build. Minimal paint brush work - most of the plane is painted with Humbrol Gloss 22 from an rattle can. The kit is quite a good one - but you MUST follow the steps in the instructions regarding the engines and intakes otherwise you end up in a lot of trouble. Do not ask how I know this. The only real downside is that the cockpit really, really, needs a pre-cut mask kit to get a good finish - I tried using Maskol and it failed. Miserably as you can see.
