True Details 1:10 Martin Baker H7 Ejection Seat
I decided to brush the dust off of my ejection seat. Here is a shot of the seat next to a bottle of primer for scale.
Originally, I had this guy primed and painted the entire thing silver. I was going to use chipping fluid to create a worn appearance. The chipping fluid I had was terrible and I scrapped that idea. I then wrestled with using oils or acrylics. I finally settled on Vallejo Model Color. This thing has way too many details to be sprayed so brush painting for me is a must. I stripped it down to raw resin and re-primed it with Stynylrez gray.
I found some stock images of a similar seat that I will use for reference. They are watermarked as I wasn't about to pay $20 per image just to have a better-looking reference.
I then used a color selector tool to isolate some of the main colors and picked out the best matches for Vallejo Model Color.
I have blocked in the main colors and will begin to pick out the pipes with a silver color. Here I plan to use Vallejo Model Air Silver as it covers exceptionally well straight out of the bottle even with a brush.
**Note the green seat is a bit too intense, so I will tamp that down with weathering effects.
Re: True Details 1:10 Martin Baker H7 Ejection Seat
This is excellent...both in subject matter and presentation
Looking forward to see it progress
:th:
Looks good. I love big scale stuff like this. I would love to build a spitfire cockpit or a Merlin engine in 1/10 scale
Started blocking in some chrome color for the pipes. I also added some different colors for belts. The color is very rough and I will have to clean up the edges.
Looking good Matt :th: amazing pieces of technology these are :th:
ChrisLX200
Post by ChrisLX200 »
Looks fantastic, can't wait to see the rest of the plane when you finish it! :-)
I got the edges cleaned up and changed the color of the parachute cover straps.
Looking good every update
Did you find your ejection loops??
Didn’t I send you a bunch of little plastic jewel boxes for small parts??
Twokidsnosleep wrote: Sat Mar 13, 2021 2:37 am Looking good every update
Yes you did, they aren’t in them; I checked. I think I am going to have to print up some new ones.
ElCapitan
Post by ElCapitan »
Never seen this sort of thing before — really interesting. Did it come in one piece?
ElCapitan
I remember this from a news release , but never saw any close up pic's. Amazing detail and complexity.
ElCapitan wrote: Sat Mar 13, 2021 9:39 am Never seen this sort of thing before — really interesting. Did it come in one piece?
The main part which is in the picture is one solid hunk of resin. There are a couple of parts molded separately; overhead handle, a launch column, and some sort of hose connection. The only one of those that I want to use is the one that is missing.
Quax
Greenland
Post by Quax »
Great stuff Matthew, sometimes the bigger it is the harder it is to get right but you're certainly on the right track :clap: :clap:
A mess as usual...
I have taken a little creative freedom and modeled my replacement ejection handles. I am working on adding some texture to the handles to simulate the fabric covering. I will post an update when I figure it out.
EDIT:
I decided to make another one closer to what the picture looks like.
For giggles, I rendered it.
Wow, that is cool👍🏻😎
Twokidsnosleep wrote: Mon Mar 15, 2021 5:15 pm Wow, that is cool👍🏻😎
Oh yes what he said very 8-)
It bothered me that the handles didn't have any "sag" to them and were completely flat. It took me a while to figure out how to make them move in a couple of different dimensions, but I think these look better.
ElCapitan
Post by ElCapitan »
That looks amazing - are you planning to 3D print?
ElCapitan
ElCapitan wrote: Tue Mar 16, 2021 11:20 am That looks amazing - are you planning to 3D print?
Yes, I have a Peopoly Moai resin printer. I am just working out the slicing and support structure.
Well, the good news is that the second print was successful.
The bad news, I got the dimensions wrong and it looks like a cartoon.
Casper
Post by Casper »
Second print came out really good Matthew and looks great even though a little big and will look perfect when resized. :clap:
MBB Design© Mini Bike Bench©
Never mind the next one will be the money shot.
That looks excellent1 Once you have the dimensions down it's going to look great!
I took my reference photo and scaled my design to match. However, I still think it is too big. I am not sure this is due to the perspective of the reference or the actual model itself not quite being the same.
Thoughts?
Casper
Post by Casper »
Fixing bar looks the correct size but the loops look a little too big, are you able to reduce them slightly in cad Mathew
Mark
Really cool build! Looking great so far.
I agree with Casper, its the loops that are just a little outsized. :th:
I edited the model (again) and created a thread for the process. I will print it this afternoon when I get home.
viewtopic.php?f=10&t=29309
Still not perfect, but I am going to go with it.
That’s a winner Matthew 👍🏻😎
Looks spot on!
I think wrapping tape around the handles is the way to go.
Ignore the blutac; I’m not ready to permanently attach.
Excellent! Such a cool project!
I worked on getting some more color onto the seat. I switched from Vallejo to Mr Metal for the brass. I also used a toothpick and some Molotow chrome for some bolt heads. I decided to go with blue for the top parachute cords (I think that’s what those are). It is a bit anachronistic, but I think it pops nicely.
Casper
Post by Casper »
:clap: That's excellent Matthew and the tape looks perfect, love the textured bracket.
Molotow pens and paints are brilliant, it can rub off sometimes when handling your model but doesn't smudge across other paint and a quick touch with the pen really looks great. Not tried it through a brush yet though.
mark
Really well done so far!
Keeps getting better and better :th:
A big thank you to Matthew for opening up a 3D printing section on the forum
Awesome idea
Very nice work. I love the ejection handles. I could never have been a jet pilot, pulling on the handle would have been too much of a temptation :lol:
Casper wrote: Mon Mar 22, 2021 2:32 am :clap: That's excellent Matthew and the tape looks perfect, love the textured bracket.
mark
The toothpick is my favorite way to apply, but I have brushed. It even thins with MLT if you are brave enough to spray it! I will be clearing the model next to protect the paintwork before weathering. That should lock in the chrome parts.
bfrd wrote: Mon Mar 22, 2021 11:32 am
Buy the refill tube if you want to spray it...straight out of the tube no diluting
It is as easy a chrome as you can get if you can leave it along for a good week to harden over
Casper
Post by Casper »
Twokidsnosleep wrote: Mon Mar 22, 2021 3:02 pm
I got this chrome drip stick rollerball when I got my first pen, I'm on my second pen after stepping on the first :roll: I tried the ball pen on a pad and the chrome looks a different shade, kinda darker. on the label it just says chrome 862.006. It pools very well when using a brush and looks very convincing and the pens are perfect as you say for finishing touches.
mark
I did a quick dry brush with Citadel Necron Compound. I then cleared it with Aquagloss.
EDIT: Here is the back
Almost home!
I got the panel liner on, taped up the seat release, and glued on the ejection handles. The only thing left is to put a final clear; I plan to use dullcote.
Just loving it Matt :banana: :th: :pop:
Kevthemodeller wrote: Thu Mar 25, 2021 7:55 am Just loving it Matt :banana: :th: :pop:
What he said :clap: :clap:
Casper
Re: True Details 1:10 Martin Baker H7 Ejectionn Seat
Post by Casper »
:clap: Some very nice details picked out. Bravo
Super just super
SO good to see something a bit different take form on the Forum
Now that is impressive beyond mere words. :bow:: Congratulations!! :cheers2:
    Absolutely excellent work! Very great build!
    Wow your paint skills are really giving it life.
    :clap: :clap: :clap:
    Return to “Everything else”
