AFV Club 1/35 FV107 Scimitar - Bosnia 1994
ElCapitan
Post by ElCapitan »
Excited to be joining this Group Build, as it's one of the ones I voted for.
As always, I like to search eBay for something a bit different, which fits in nicely with the concept of the GB. In this case I've found a really nice looking kit for a FV107 Scimitar. I was torn between finishing this as a Falkands unit or a UN peacekeeping unit from the Yugoslav wars. I have decided to go with the latter, despite how much I dislike using white paint :doh:
Not too much in the box - it's a relatively small tank after all. It does include a PE fret and a metal barrel which is quite a nice addition. Further down the line I may look for metal tracks for it, but will see how I feel.
Hope to get started on this later today.
ElCapitan
Re: AFV Club 1/35 FV107 Scimitar - Bosnia 1994
AFV do nice kits mostly and this looks nice.
For metal tracks I think your best bet is Master Club:
MASTERCLUB MTL35218
Metal Tracks for 1/35 CVR(T)family /Scorpion/Scimitar/Sultan
200 track links, 190 rubber pads, 400+ tracks pins
The pads are important as the CVR(T) family all run on Composite Material track pads, not bare metal tracks.
    Very cool kit!
    Nice subject for the GB... not a lot is seen from that huge conflict ! Can't wait to see the build !
    ElCapitan
    Post by ElCapitan »
    RangerNeil wrote: Thu Jan 13, 2022 2:22 pm For metal tracks I think your best bet is Master Club:
    MASTERCLUB MTL35218
    Thanks for the advice. I assume the rubber doesn't need painted, is that right?
    ElCapitan
    ElCapitan wrote: Fri Jan 14, 2022 9:47 am
    MASTERCLUB MTL35218
    I think so - not physically seen their CVR(T) tracks fresh from the pack only on completed models. The real pads I've seen too many of - the material is black but the contact surfaces on them would look a dark grey, scuffed and nicked on the edges.
      Awesome - looking forward to seeing this go together as I have the AFV Club Scorpion buried in the stash & also have the masterclub tracks on the wishlist.
      ElCapitan
      Post by ElCapitan »
      I suppose it's time I posted some progress photos...
      It's going together really easily so far. As is often the case, everything started with attaching the suspension arms to the lower hull.
      No drama there - they all line up nicely. The instructions ask me to put all the wheels together next, but I need to be in the mood for that, so I'll do those later. Instead I worked on the upper hull, which included a nice PE exhaust guard. To bend this into shape I laid it flat on top of some Ultimate buffers and rolled a thin rod over it repeatedly until it curled up to the correct radius.
      Next up I'll start working on the turret. I'll have to do the wheels eventually, I know!
      ElCapitan
      Great to see it's underway and behaving so far :)
      ElCapitan
      Post by ElCapitan »
      Progress has been made on the turret now. It looks like it's going to have a lot of parts but hopefully nothing problematic.
      It's a nice little kit. The only thing that's slightly disappointed me so far is the use of chamfered edges as joins when putting together storage boxes. There's so much risk of misalignment, and the fit is never as good as with a simple locator pin or grooved method.
      ElCapitan
      ElCapitan
      Post by ElCapitan »
      The turret is all finished now - it's fairly cluttered to say the least.
      The metal barrel looks nice.
      And what's this?...
      Got the wheels out the way too :banana:
      And even got it all primed today
      I've primed in black instead of white, as I feared that a white primer coat would make the main colour coat look TOO white, if you know what I mean.
      ElCapitan
      That is going well !! Keep it up !
      Nice work Rob - that's really cracking along & looks great :th:
      ElCapitan wrote: Sat Jan 22, 2022 3:45 pm
      I've primed in black instead of white, as I feared that a white primer coat would make the main colour coat look TOO white, if you know what I mean.[/b]
      Good move - remember In reality these were painted white over the top of the standard NATO green/black. So you should get a pretty good match to the colouring!! :)
        Nice progress, this is a really cool kit.
        Wow Ya duck out for a minute next thing it's almost fully built.
        ElCapitan
        Post by ElCapitan »
        It has come together pretty quickly (certainly when compared to my last few completions!!)
        I've painted it white, using Mig Ammo acrylic through an airbrush for the first time - seemed to go down okay, although I still prefer to spray Tamiya acrylics.
        Then before I remembered to post an update I went ahead and did some detail painting and decals, so it now looks like this:
        I've left the sprockets off to make it easier to add the tracks - I'm just going to use the vinyl ones as they look okay. I'll start weathering later, though I don't have a plan of attack for that yet - I don't want to use anything too dark. I have a few grey products I will probably use in some way.
        ElCapitan
        ElCapitan
        Post by ElCapitan »
        Thanks for all the comments guys - the final reveal post is at viewtopic.php?f=753&t=30021
        ElCapitan
