Bf109F vs 109 G
UKscalemodeller
Bf109F vs 109 G
Post by UKscalemodeller »
You may have to be a closet rivet counter to know this but....
apart from the bigger cooling scoops and a fuel filler relocation, does anyone know of any significant visual changes between the F series and the G-2?
also, does anyone know where I can find pictures of said scoops?
Thanks.
T3hGuppy
Re: Bf109F vs 109 G
Post by T3hGuppy »
One has an F at the end the other a G :nena:
Too much to list. !!
UKscalemodeller
Re: Bf109F vs 109 G
T3hGuppy wrote:One has an F at the end the other a G :nena:
Arrghhh! I wish I had never asked now, all I wanted to do is see if I could get away with using an F2 as a G2 but this is all too much information!
Re: Bf109F vs 109 G
Main external differences were as you say, small scoops on the engine cowling for the spark plugs.
Seen here (small scoops between the spinner and main scoop on the blue band).
The wheel wells had squared off ends as well
And I believe the prop blades were "fatter" than on the F series.
Panzerwolf
Re: Bf109F vs 109 G
Post by Panzerwolf »
The G versions had some differences in the cockpit. For example some late Gs as the G-10 used a special 'Erla' canopy, looks a bit different, but that's not important for a G-2. The G-1 was the first Bf 109 to utilize a pressurized cockpit, the G-2 lacked it though. Only difference is that the G-2 could be equipped with various additional weapons (Rüstsätze). If they mounted one though, a 'R' suffix was added to the designation, such as G-2/R2 (reconnaissance aircraft).
WIP
Tristar PzKpfw 38 (t) Ausf. G
Hobby Boss T-40 Soviet Light Tank
Panzermeister36
Re: Bf109F vs 109 G
Post by Panzermeister36 »
http://en.wikipedia.org/wiki/Messerschm ... b-variants
http://en.wikipedia.org/wiki/Messerschm ... 09G_models
Mainly small differences in armament and engine ventilation, but it all depends on what sub-variant of the '109 F or G you're trying to build; each one had about 6 sub-variants. :crazy: :scratch:: :think: :wall: :wtf:
Read through these articles and that should give you an idea. :thumb2:
Unleash the DShK!
http://www.youtube.com/user/Panzermeister36
WIPs
Dragon Sd.Kfz.7/2 FlaK 37 - Adam Mann's Halbkettenfahrzeug Gruppenbau
Dragon StuG IV Early - Unarmed Snowplow Modification
Trumpeter BMP-1 w/ BTR-70 Turret
Cyberhobby Geschützwagen 38M FlaK 103/38 - "M" GB
HobbyBoss T-40
Meng T-90
Orochi M3A3 Bradley
UKscalemodeller
Re: Bf109F vs 109 G
Thanks All. :thumb2:
I think I can probably get away with it , I'll try adding the extra scoops (one just below the front of the canopy as well I believe)
Something above and behind the exhaust appears to have moved upwards, I'm not sure how important that is. My 'Friedrich' does not have the under wing cannon gondolas and so the adding the scoops should be enough methinks
Re: Bf109F vs 109 G
The G also had thicker canopy framework, but I wouldn't worry about that detail on a 1/72 model!
UKscalemodeller
Re: Bf109F vs 109 G
Gav0909 wrote:The G also had thicker canopy framework, but I wouldn't worry about that detail on a 1/72 model!
Yes, it shouldn't matter at 1/72 I hope.
As long as it doesn't come up against any rivet counters it should be fine
