Meng 1/35 D9-R Armoured bulldozer
muskegman
Post by muskegman »
Just completed and all hand painted using Vallejo paints. I wanted to achieve a clean looking build like it just came out of the factory.
I decided to go with the IDF Combat Engineers School Bahalatz August 2008 scheme because I really liked the colour.
I thoroughly enjoyed building this right from the start, it is a very well engineered and thought out kit and was fun to build. Most of the pieces virtually snapped into place. A fair amount of sanding was needed on some of the parts because of the ejection points on the mould which were fairly easy to remove but were in places that are in full view. I would certainly buy another kit from Meng this was the first one from them I have built and I was not dissapointed, although they are a bit costly in the end I thought it was worth it.
timtamtung
Re: Meng 1/35 D9-R Armoured bulldozer
Post by timtamtung »
awesome build!
-tungy
To do list:
Russ72
Post by Russ72 »
Nice work. That's a mean looking machine.
Oh wow!!! You brush painted that!!?? That's spectacular bud.
I don't know of anyone that's done that. Ha. Excellent work.
muskegman
Post by muskegman »
Thanks for the comments guys and yes Coen its all done with a hairy stick using Vallejo Air Hemp 71023. I could only find this particular shade in Vallejo Air and not in the Vallejo Model Color range. The first coat I applied with the brush was very thin and like water, after that dried the second coat was a little darker but it took quite a few coats eventually building up into a very smooth plastic like finish. I love these Vallejo paints since I have made the switch from Humbrol and Testors enamels. With a little patience and the right wide brush they look great with very little if any sign of brush strokes.
HamilkarBarkas
Post by HamilkarBarkas »
Exceptional looking model, it is impressive! who says we need weathering, sometimes a thing is so beautiful that you simply can not cover it with anything else :)
muskegman
Post by muskegman »
HamilkarBarkas wrote:Exceptional looking model, it is impressive! who says we need weathering, sometimes a thing is so beautiful that you simply can not cover it with anything else :)
Thankyou for the comment Hamilkar, it means a lot coming from you :D and yes that was my thought exactly about the weathering.
billk
Greece
Post by billk »
Sweet build and really interesting model.
muskegman
Post by muskegman »
Cheers billk :)
AchtungPanzer
Post by AchtungPanzer »
Very good clean work - Bulldozer straight from the factory :th:
PaulAyrey
Post by PaulAyrey »
Excellent! Well done on a superb finish!
TechHead
Post by TechHead »
Awesome finish! I'm particularly impressed since it was hand brushed as well... this is making think about switching back to hand brushing as I just can't get to grips (or have any success) using an air brush.
Keep up the good work! :)
Currently On The Bench/Humbrol Modelling Tray:
Airfix 1:72 Hawker Typhoon
Airfix 1:32 Mini Cooper S
Man Stash:
Airfix 1:72 Spitfire Mk.IXc
Airfix 1:48 Messerschmitt Bf109E-4/E-1
Return to “Land Gallery”
