Trumpeter 1:35 DF-21 Ballistic missile launcher
gaz45
Post by gaz45 »
Looks like i'm the first up
I apologise for the long post but there is a lot of plastic in this kit over 24 sprues
The box art
box full of plastic
sprues with some very nice detail and very little flash
Clear parts are very clear
Enough tyres to build 4 6 wheeled kits lol
Metal axles with copper wire and pvc wire
A first for me some PE
Decals
Instuctions
The history part
Chinese DF-21 Ballistic Missile (CSS-5)
The DF-21 (NATO code name: CSS-5) is a two-stage, solid-propellant, single-warhead medium-range ballistic missile (MRBM) system developed by China Changfeng Mechanics and Electronics Technology Academy (also known as 2nd Space Academy). The missile design is based on the two-stage JL-1 submarine-launched ballistic missile (SLBM). The DF-21 is capable of delivering a 500kT nuclear warhead over a distance of 1,800km. The improved DF-21A was reportedly introduced in 1996.
In March 1967 the Commission of Science, Technology, and Industry for National Defence (COSTIND) decided to develop a land-based solid-propellant strategic ballistic missile. However, due to the impact of the Culture Revolution, the missile development did not start until August 1978.
In 1979 the solid-propellant ballistic missile design team, which was also in charge of the JL-1 submarine-launched ballistic missile (SLBM) development, was subordinated to 2nd Aerospace Academy, with Huang Wei-Lu appointed as the chief designer. The proposal to develop the DF-21 land-based medium-range ballistic missile (MRBM) based on the JL-1 SLBM design and technology was finally approved by the PLA in June 1980.
chinese df-21 transport
The road-mobile DF-21 MRBM system (Chinese Internet)
As well as the development of the ballistic missile, 2nd Aerospace Academy was also responsible for developing the transporter-erector-launcher (TEL) vehicle, missile canister, missile testing and aiming, and other launch and ground support systems. These systems had received rigid tests in various environment and weather conditions in 1984.
The first test launch of the DF-21 missile took place in May 1985, followed by a second test launch using modified ground support system in May 1987. The missile entered operational service in the late 1980s. In the mid-1990s, 2nd Aerospace Academy also introduced the improved DF-21A (CSS-5 Mod 2) with increased range and accuracy.
The DF-21 is a two-stage, solid-fuel, single-warhead medium-range ballistic missile system designed to provide target coverage in Asia and West Pacific regions. No detailed information is available regarding the missile’s performance or design, but it is estimated that the DF-21 might be similar to the JL-1 SLBM in general aerodynamic layout. The missile might uses nozzle controls with no stabilising fins.
df-21 launch vehicle
DF-21 in the 1999 national day parade (Chinese Internet)
The missile uses an inertial guidance, coupled to a terminal radar-guidance system to increase the accuracy. The missile’s CEP is estimated to be about 300~400m. The missile carries a single 100kT, 200kT, or 500kT nuclear warhead, but can also configured to carry conventional HE warheads.
The missile is contained in an alumni-alloy cylinder launch–tube which keeps the missile in an invariable temperature environment. The launch tubes have an elevation range of 0 to 90 degrees. The azimuth range is from -180 to +180 degrees. The missile launch-tube is carried on a 3-axes semi-trailer TEL, which is towed by a HY473 6X6 tractor truck. The TEL trailer and tractor are equipped with hydraulically operated stabilisers which are lowered in preparation for the missile launch.
Operational Deployment
It is estimated that so far around 40~ 50 DF-21 missiles and 30~40 launcher systems may have been deployed by the PLA Second Artillery Corps in 4 locations:
Tonghua, Liaoning Province, near Korea Peninsula, Japan and the Far East Russia
Liangxiwang, Jiangxi Province, near Taiwan Strait
Jianshui, Yunnan Province, near South-East Asia
Xining, Qinghai Province, near China-India border and Middle Asia
These missiles are generally deployed in areas closer to China’s borders to ensure adequate target overage of areas previously covered by the DF-3 IRBM, which has a longer range, but is less accurate compared to DF-21. Many reports claimed that some DF-21 missiles are fitted with conventional warheads but this cannot be confirmed. The total number of DF-21 in deployment may not increase significantly in the future since the PLA has already deployed enough number of DF-11 and DF-15 theatre missiles for potential regional wars.
df-21 launcher
Operational DF-21 unit
Specifications
Configuration: Two-stage
Length: 10.7m
Diameter: 1.4m
Launch weight: 14,700kg
Propellant: Solid fuel
Guidance: Inertial + terminal radar guidance
Range: 1,770km
Deployment: Road mobile, 6X6 tractor truck + 6-wheel trailer; or silo
Re-entry vehicle mass: 600kg
Warhead: Single 500 yield kT nuclear
Accuracy: CEP 300~400m
Launch preparation time: N/A
Looking forward to starting this but it'll have to wait till next week with work
Thanks for looking and any comments and hints/tips are appreciated
Re: Trumpeter 1:35 DF-21 Ballistic missile launcher
Never seen one of these built before, so this'll be different. Looks like a cool kit...will be pretty long, about 11 inches I guesstimate at 1/35th scale :) :thumb1:
Yevgeny
Post by Yevgeny »
This looks very interesting. Looking forward to see more :banana:
Sir, we're surrounded!
Working on:Trumpeter (00204)
LTmodelmaking
Post by LTmodelmaking »
Interesting. You don't see people building Chinese vehicles that often. Looking forward to this build.
Good luck with the kit !
Its an Older Trumpeter kit ..... late 1990's or Early 2000 and it could be riddled
with EPM's so take your time and have fun !!!
the Camo is challenging and very nice.... should be very cool to see it come together !
Best of luck ! :cheers2: :thumb2:
AlkaSeltzer
Post by AlkaSeltzer »
That is going to be a massive build! Good kit and I look forward to seeing your progress. :th:
ROBOPAUL
Post by ROBOPAUL »
OMG is 3 months going to be long enough to build this monster. Good luck.
gaz45
Post by gaz45 »
i'm hoping so
LudvigN
Post by LudvigN »
Have fun with this beast, will surely be a long one :crazy:
Ludvig :cheers2:
Airfix 1/72 A-4 Skyhawk
Last one finished:
Bandai 1/72 A-Wing Gallery
Tiger131
Post by Tiger131 »
well this is the biggest in the sig so far good luck and look forward to seeing your work
Unit53
Post by Unit53 »
WOW! Now this is a lump, great looking kit and a very different subject, will be following this one with interest.
Good luck with the build
Martin
fly1ngdutchm4n
Post by fly1ngdutchm4n »
BIG! :eeek:
Love it, great choice!
Good luck mate :thumb1:
That is going to be huge
Can you make it in a launch setup or only in transport
And if so what will you do
trekfanj
Post by trekfanj »
Great entry! :th:
Jarod
-Ralph Waldo Emerson
FlyingCoffin
Post by FlyingCoffin »
Looking forward to seeing this one! Looks to be a really interesting kit. :pop:
Per Ardua ad Astra
"In the end, this thing has earned its morbid moniker. This "flying coffin" lends a war which they call great, a glamour that it simply does not have."
On the Bench: On Deck:
  • Eduard 1:72 Fokker Dr. I
In the Aerodrome:
  • Nothing, yet!
gaz45
Post by gaz45 »
Thanks guys and MarkVerploeg if i can have it in launch setup i will
So thought i'd make a start as there is a lot of plastic i wasn't sure wether to work through the instructions or get some of the smaller sections made up so here is was i have so far.
Most of the engine parts which i will make up and paint before adding the copper wiring
The steering column parts
The back seat
The front seats
Mid section for the drive chain i think
The front axle assembly
[URL=http://s966.photobucket.com/user/Gary_W ... 20141021_1
51128_zps739345a1.jpg.html]Image[/URL]
Stowage and the 2 fuel tanks
The dash board
My first ever time using PE this part goes inside the cab on the roof so won't really be seen
Parts on the cab underside
The right and left air cleaner assembly
More air tanks with PE edge
Something that goes in the cab under the dashboard
Last up the centre and rear axle assembly
Thanks for taking a look and sorry for any blurry photo's i'm breaking in a new phone
I do have one question i would like help with the tyres are rubber and they are painted to look like white wall tyres any help with how i can do this would be very much appreciated.
The plan is to get these parts primed up tomorrow.
That is a big kit indeed
The white walls remind me of this from Cars
Tiger131
Post by Tiger131 »
thats some orange plastic for the engine you cracking through this build looking real nice
gaz45
Post by gaz45 »
Right lots of bits ready for priming
All primed up
Forgot to take pictures of the wheel arches with the PE on the edges before primin
g
Today i got quite a lot of the assemblies painted to hopefully to start assembling something
The front and rear seats were painted in revell 381 brown withe the base of the front seats in tamiya xf-5 flat green and the seat mechanisam in revell 91 silver
Next up was the dashboard were i used tamiya xf-1 and revell 91 silver along with the steering wheel also in tamiya xf-1 these were both dry brushed with the brown ( revell 381 from the seats) to give a warn look sorry if this cant be seen frome these pictures
Next up was the engine painted with revell 30 orange and parts picked out in tamiya xf-1 and revell 90 silver and mr hobby coca brown for the drive connection
Image[/
When this was dry it was time to add the copper wire
[URL=http://s966.photobucket.com/user/Gary_W ... 4.jpg.html]Image
Which were then covered with the exhaust pipe manifolds
Image[/URL
[URL=http://s966.photobucket.com/user/Gary_W ... c.jpg.html]Image
The stowage and 2 fuel tanks were painted using tamiya xf-1
lastly for today the front, centre and rear axle were painted with mr hobby cocoa brown
with the inside of the cab floor painted using tamiya xf-5 flat green and vallejo model air rlm70 black green
hopefully the next update will see these components put together
Nev
Post by Nev »
Awesome mate :thumb1:
On the Bench...
rwsmith14
Post by rwsmith14 »
Great unique subject interesting ! Good Luck !! :cheers2:
gaz45
Post by gaz45 »
Next update
Firstly i dirtied the engine with thinned tamiya X-19 smoke
Image[/url
[URL=http://s966.photobucket.com/user/Gary_W ... a.jpg.html]Image
While that was drying i assembled the inner cab along with the decals on the dashboard ( the decals were a nightmare )
The air cleaner system was painted with Tamiya XF-1 flat black and Revell 90 silver
Next up i added the windows to the cab along with the vent and the vent/scoop on the roof
Also made a start on the trailer assembly sections
So far this kit as fitted together very well with very little clean up needed there are a few IPM that will need to be filled if they are seen
Once again thanks for looking and as usual and comments are much appreciated
Tiger131
Post by Tiger131 »
cracking on with your build and doing a great job look forward to seeing more
gaz45
Post by gaz45 »
just a small update got some more construction to the trailer frame work and again the fit is very good
Great work so far...she's starting to take shape nicely now mate :) :thumb1: :thumb1:
fly1ngdutchm4n
Wow, great progress so far :thumb2:
Love the copper wire at the engine, make all the difference
gaz45
Post by gaz45 »
thanks for your comments
got quite a bit done the last couple of days
The stowage for the trailer assembled and fitted then all primed with ammo grey primer
The chasis frame painted up with mr hobby H78 olive drab and assembled with fitting the engine and prop shaft gear and the front wheel assembly
Fitted the pvc brake lines to the centre and rear axle assembly
assembled the lorry wheels along with the mud flaps with added PE
The rest of the lorry parts cleaned up and primed
And just to finish the cab interior i dry brushed the foot wells with revell 381 brown and wiped some very thin revell 84 leather brown
I appologise for some of the picture quality i'm getting to grips with the camera on my new phone.
Thanks for taking a look and again all comments welcome.
Tiger131
Post by Tiger131 »
thats one cool looking chassis its coming along real nice
Russ72
Post by Russ72 »
Great progress so far. Looking good. :thumb1:
http://s966.photobucket.com/user/Gary_W ... d.jpg.html
My Gawd ! those Ejector Pin Marks are HUGE !!! and Deep !
are they covered by some other parts ???
I have this kit and now it Hurts to find out.. so much Work will be needed to clean all that up !
Good work so far !
but man... the EPM's ... . ouch !
gaz45
Post by gaz45 »
they are on the underside so will be hidden by the tyres hopefully but after a dry fit if they are visible a spot of filler and touch up and a wash will sort them out to be far to the kit i think that those are the only EMP's so far that may be seen.
:th: :thumb1: :cheers2:
gaz45
Post by gaz45 »
Right got a little more done on the cab chassis but having a little trouble getting the centre and rear axle fitting right. the exhausts are fitted along with a few other bits and bobs
the exhausts were painted in revell silver and mr hobby H76 burnt iron
next up the trailer axles
then some components for the canister assembly
Image[/URL
[URL=http://s966.photobucket.com/user/Gary_W ... d.jpg.html]Image
The 5th wheel i believe its called
The canister itself is not the best of fits so with some tamiya putty and some mr surfacer should sort this out
Thats where i'm upto for now thanks for looking
hansolo
Post by hansolo »
Wow this is an epic build. So many parts and details. You are truly putting a lot of effort into it.
What do you use for filler? At the moment I use mr. Surfacer but that stuff is so thin.
Hansolo
martin57
Post by martin57 »
looking great so far , theres a lot of plastic to deal with , best of luck with the rest :thumb1:
gaz45
Post by gaz45 »
hansolo wrote:Wow this is an epic build. So many parts and details. You are truly putting a lot of effort into it.
I also use mr surfacer but for bigger gaps i use tamiya putty mate
Nice work thus far!
Keep up the good work! :cheers2:
kiwigav
New Zealand
Post by kiwigav »
Nice progress mate :th:
Cheers Gav
Great build mate looking forward to the next update.
JayCub
Post by JayCub »
That is a lot of parts, and one im more than interested to see built up
Tom
gaz45
Post by gaz45 »
Right managed to get quite a bit done over the last few days
A few more parts to the canister theres about 40 of these
The canister is complete
The rear suspension and axles in place
The fuel tanks and air cleaners added
Made a start on the white wall tyres I base coated them with vallejo model air white 71.001 then coating them in tamiya XF-2 flat white
Next i added the mirrors, handles and rails to the cab ready for priming and masked the windows
More PE parts mud flaps and grills
The truck wheels are painted up in tamiya XF-1 flat black and Mr Hobby H17 cocoa brown
The trailer wheel hubs all assembled
The rest of the parts ready for priming the spare wheel plate and support bar, truck bed and trailer axle clamps
and the canister supports
Thats it for a few days as work gets in the way but hope to get all the priming complete mid week.
Thanks for taking a look and your comments are always welcome.
Tiger131
Post by Tiger131 »
Love the white wall tyes will look quality when there attached to that big ass missle launcher
Yevgeny
Post by Yevgeny »
/\ agree. Is this parade version then?
gaz45
Post by gaz45 »
Just a small update the cab and the rest of the assembled parts are all primed up including the canister
The trailer wheel hubs and PE mud flaps painted up with tamiya xf-1 flat black just need to do the centres with mr hobby H17 cocoa brown
base coated these parts with mr hobby H78 olive drab
as i have ran out of the olive drab and waiting for delivery i thought i would try my hand at pre shading and im quite pleased how it has turned out for my first attempt
Thats it for now as im waiting for paint thanks for taking a look
:cheers2: Good progress !
Keep up the good work !
gustavlekstal
Post by gustavlekstal »
It's gonna look great this one! :th: great work
Regards Gustav
Dragon t-34/85 premium mod 44
viewtopic.php?f=29&t=10747
viewtopic.php?f=29&t=12313
