1/48 MENG Me 410B-2/Ua Heavy Fighter
rodrant
Post by rodrant »
Hi ,
Since i finish the Vietnam pibber for the GB , I wasn't quiet , so build my MENG Me 410 'Hornisse' , the build is a beautiful kit , Decals from Cartograph ( the only complaint that I had on the kit , the number of decals aren't enough on some ,as an example , the ones to place in the small ailerons in the tail and on the wings ...but not very important to my point of view ) . I make the option to place the engines closed an the gun bay fitted , but and maybe I will for another one just to show all this detail , the engines are just perfect and with a lot of potencial to the modeller that wish to show a detailed Daimler Benz WW2 Engine ! The cockpit details are gorgeous and no need to buy after market on this one , it brings some PE parts for the seat belts and for the radiator engine ...even it isn't the most perfect paint job , here are some photos ( on Daylight ! Yes it is a first one to me :lol: )
The gear is also very fragile ( even in this the kit is as the real thing , seems that was a problem on this beautiful airplane )
The base is a corck frame , I place some Noch diorama grass sheet on top and make a hole to place an eduard kit for a wooden airfield surface , painted in Wooden deck from tamiya and weathered with AK for Wood and some stains of kerosene for AK also .
On this plane I use the new AK interactive RLM colors , and they are very nice to spray . use also their black primer .Had an issue for the first time as I do not usually wash the parts before assembly or painting , but this kit bring a lot of grease from the injection process , and the primer did not 'grab' well at first .So I Advice to wash the parts before assembly as it was an issue with this grease and not with the primer that even though worked perfectly , and this colors are very nice to use !
The moting was done using an Eduard moting mask etch set , and it works very well if used carefully .
Weathering done with Ultimate Dark Dirt wash !
Hope that you like this plane ! I recommend it to all of you interested in Luftwaffe or WW2 subject ! A very nice kit to build Out of the Box ! :th:
Cheers ,
António
a lot of stuff right now :-)
Re: 1/48 MENG Me 410B-2/Ua Heavy Fighter
That looks like a very nice kit Antonio and the ME410 is an aircraft that I like the look of. You did a beautiful job mate....those mottling masks seemed to have done the trick very well! :thumb1: :thumb1: :clap: :clap: :bow::
Cheers :cheers2:
Martin
rwsmith14
Post by rwsmith14 »
Beautiful job !! :thumb2:
Yevgeny
Post by Yevgeny »
Cool looking plane, love the camo :)
Good kit?
Sir, we're surrounded!
Working on:Trumpeter (00204)
CJSomerset
Post by CJSomerset »
:clap: Nicely done! I'm struggling with the same camo pattern at the moment. :clap:
rodrant
Post by rodrant »
Yevgeny wrote:Cool looking plane, love the camo :)
Good kit?
Hi Yevgeny ,
IT is a very good kit in my opinion , even If you are in the more detailed display you have the option to depict the engines or the gun bay that have a wonderful detail OOB .
Definitely I recommend this kit !
Cheers ,
António
rodrant
Post by rodrant »
UKguyInUSA wrote:That looks like a very nice kit Antonio and the ME410 is an aircraft that I like the look of. You did a beautiful job mate....those mottling masks seemed to have done the trick very well! :thumb1: :thumb1: :clap: :clap: :bow::
Cheers :cheers2:
Martin
Thank you Martin , yes I use for the first time an Eduard Template( I call it a Mask etch ...it is really a template...) for the mottling and worked quite well , I have an Heinkel HE 219 UHU from Tamiya and will use it again as the color scheme has this mottling also .
rwsmith14 wrote:Beautiful job !! :thumb2:
CJSomerset wrote::clap: Nicely done! I'm struggling with the same camo pattern at the moment. :clap:
Thank you rwsmith14 and CJSomerset for the nice comments !
Cheers ,
António
Yevgeny
Post by Yevgeny »
Good kit?
Hi Yevgeny ,
Thank you :)
I have Meng kit sitting for next year GB, and may consider plane one :)
shortCummins
Post by shortCummins »
this kit is on my wish list, seeing your great model just moved it higher up the list, great job
